edison123
- Oct 23, 2002
- 4,508
Need some advice for a transformer-rectifier for electroplating application.
Quantity - 2 nos.
KVA - 600
Voltage - 11 KV / 100 V
Configuration and usage - Both of them connected to the same 11 KV bus on the primary side. One transformer or both the transformers may be used depending on the load requirement.
Requirement - Minimum harmonics
Given the above, what is the best transformer winding connection that would give the minimum harmonics and circulating currents (if any)
1. Both transformers Delta / Delta
2. Both transformers Wye / Delta
3. One transformer Wye / Delta and the second one Delta / Delta
Muthu
Quantity - 2 nos.
KVA - 600
Muthu
