I have the need to convert 120VAC to 24VAC. A 1VA transformer is to big for the package. I need to design a supply to source about .75 VA. I really don't want to use a resistive supply as this generates alot of heat (5-7W) and is very inefficient. I am thinking of a capacitive circuit, cap in series with the AC to limit the current using the reactance of the cap. I believe they use these types of circuits in appliance control.
Below is one design link using half wave rectifier. This is microchips app note AN954 and is good for about
15mA.
(forgot how to insert pics)
Below is yet another link using full wave rectifier from microchips document TB008.
I have always known about a capacitive supply but never really dove into it much until now. I believe my requirements are feasible using such a design, just not sure if I am going to gain much board space using this method over a transformer depending on the requirements of the front end cap. I can come up with the capacitance, voltage, etc on my own just not sure if UL has any requirements for this cap to be class X capacitors. I always thought these were more for suppression but I thought of using them but the footprint is large compared to standard eletrolytics. I am thinking class X would be overkill, especially if I use transient protection such as an MOV and/or other suppression. Microchip does mention the second circuit requires R1 and R2 in order to achieve UL approval. R1 is for current limiting and R2 is for bleeding off the charge. I don’t believe the fuse is necessarily required as it only protects for the line and neutral from being miswired.
I will not be using either one of these circuits directly. However, I will likely be using full wave rectifier with the components on the line side to limit the traces with 120Vac on them (spacing). I need about 55mA at 12VDC but I am thinking I will change by biggest load (relay coil @12VDC is about 37mA) to operate on a different voltage (maybe as much as 115) to reduce the current requirements.
Anyway, I am just looking for some advise on the front end cap, as far as if I should use class X caps (I think not necessary) as well as any other advise from others who have used these types of circuits. Yes I kow the isolation is gone going this route without the use of a transformer or optics. Building a switching supply probably won't save me much space either and I would rather go the route of a resistive supply than building a switcher for this design. Thanks in advance.
15mA.
