Dear Abaqus experts/users,
I have a question regarding my Abaqus axisymmetric heat transfer model (please see attached). Initially, I wanted to run the heat transfer case first then get the temperature to find thermal stresses. The model is a very simple one, a cylinder (rectangle in 2D), with inner surface heat flux load and outer convection boundary condition. What I'm trying to do is to vary the surface heat flux with time. The code works perfectly when there's no time dependence but when I change the amplitude from instantaneous to tabular or decay and insert the time variables. I get the following error message: "Time increment required is less than the minimum specified".
Well..., I tried to lower the minimum increment as the message suggests but still no hope. It works when the time increment is ridiculously small (e-9!!!!). This is obviously not a solution as the run will take literally for ever to finish.
I would highly appreciate your help, I need this to be sorted out ASAP and would be grateful for your quick responses.
Kate
Kate
