dsengine
- Feb 5, 2005
- 8
I have a bit of a tricky heat transfer problem and was wondering if someone could point me in the right direction if possible.
There is an above ground stainless steel pipeline containing crude oil @ 10degC and 130 m3/hr. The pipe has OD 508mm and thickness 6.35mm. A heating band is then placed around the pipe diameter and heated until the outside of the pipe reached 250degC. The heating band is then removed - how long will it take the outside of the pipe to reach ambient conditions? I'm only considering radial heat transfer and assuming the pipeline is infinitely long.
In my mind this is a forced convection/conduction/natural convection problem. Forced convection from the moving oil inside the pipe, conduction through the pipe wall and finally natural convection with the ambient air. The tricky part is where the point of interest is - on the external pipe wall.
I could probably work out the steady-state heat transfer between the external pipe wall and air and between external pipe wall and oil (assuming I can find a relevant convection heat transfer coefficients) but obviously this is a transient problem - how would that help calculate the cooling time.
I'm unsure whether this could be treated as a lumped system (vague recollections about Biot number). Are there any assumptions which could be made to come to an analytical solution?
Appreciate any help or direction you can give. Many thanks in advance.
