They use either planetary gears with torque converter like cars do or diesel electric like diesel lcomotives.
None uses hydrostatic transmision like excavator does with variabile displacement axial piston pump and fixed displacement axial piston motor.
if we look overall transmision efficiency for:
1. electric transmision
alternator has power factor round 0.85,
inverter has efficiency round 0.9,
induction motor has power factor round 0.85
so overal efficiency is 65%
2. automatic transmision
torque converter has efficiency from 0 upto 80% (0 when stationary, 80% when speed sycronizes) and some is lost in planetary gearset as well so overall efficiency for dump truck would not exceed 60%
3. hydrostatic transmision
axial piston pump is reported to have 90% overall efficiency,
same goes for fixed displacement axial piston motor,
up to 5% is lost in the valves and pipes
so overall efficiency would be 77%
So why they prefer diesel-electric or diesel mechanical transmison over hydrostatic?
