Transmission Loss
geeovana
10
HI
I am designing an exhaust system for a 450cc engine. I have designed the new system out of lightweight materials with a similar internal configuration as the stock item with a range of end cap sizes. I have run the model in Solidworks Flow Simulation to calculate back pressure produced at a certain RPM.
Is there anyway to calculate the approximate dB produced by the exhaust if I know the theoretical pressure and velocity of the gas exiting the silencer??
Thanks for any help in advance
Graeme
The pressure is likely to be 1e5Pa at the tailpipe, but the instantaneous velocity will be quite lively. If you consider the orifice to be a monopole source (ok for the low frequencies you're producing), then it's quite simple. For a monopole source in the free field, pressure P(t) at a distance R from a source of strength S(t) (a.k.a. volumetric flow rate) is given by:
P(t)=rho/(4.pi.R).dS(t-R/c)/dt
Where c is the speed of sound in the air between source and receiver, -R/c is the transport delay. Then you just need to analyse the pressure signal at the receiver as you would with measured pressure.
A good book on this is: "Theoretical Acoustics", Philip McCord Morse.
- Steve
Thankyou for the replies
Yes it's a four stroke single cylinder
So if i had a velocity of 150 m/s and a maximum total pressure of 123000 Pa how would I calculate it?
Thankyou for for all the help
Graeme
Even if silencer's internal chambers, tube lengths etc are a " similar internal configuration as the stock item" I expect what comes out the end has large pressure variations with strong multi-frequency content.
Pressure variation similar to the red curve in Fig 2 here -
Or, the sounds heard around 0:40 here but with frequency based or rpm.
I think for the variation in end cap size ( opening diameter(s) or area, or ??) to change the exhaust sound very much it might be a result along the lines of an acoustic "plenum chamber" as shown about 1/3 down the page here -
If the end cap succeeds in creating "back pressure" of a few psi in operation the power may be suppressed a bit too.
Some general silencer effects here-
If you want a CAE prediction of exhaust noise, your CAE tool will need to be able to predict tailpipe velocity as a function of crank angle (or time). The mean value will not really help - it's the pulsations that make/are the noise. There are some CAE tools available for free that can simulate this - having just a single cylinder makes that choice wider.
- Steve
