If you go to the body's properties (right click on the body in the tree, select "properties"), there a transparency slider under the "graphic" tab that may work depending on exactly what you need. I think you can make things behave a little differently depending on if you apply the transparency property at the body, part, or subassembly level in the tree, although it's been a while since I've played around with this so I might have that wrong.
