I am wondering whether it would be possible to "trick" ABAQUS in order to assign two different material properties on the same element. From what I've tried so far, if I assigned two different section assignments with two different material properties on the same part, ABAQUS will only consider the second section assignment. The first one will not be used.
The reason why I'm trying to do that is I want to model an element which consist of something like an isotropic matrix and anisotropic fiber. Does anyone have any suggestion?
