  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Trimming
vitulin
Automotive
Nov 1, 2007
79
0
0
EU
I wonder if its possible to trim a curve in a way, that part of the curve stays construct and the trimmed part changes to reference.
Vit
I am using NX 4.04
Vit,
I think what you want to do sounds like what can be found under settings pull down in curve trim. You set the output to associative and the input curve to keep in NX-5, or retain in NX-4. The original curve will afterward be displayed in dashed lines.
Best Regards
Hudson
You could just divide curve by bounding curves and then change the object display of the curves as desired.
Gary Ashby
Designer
UG/NX V8 Thru NX5
SolidWorks 2007
AutoCAD 2002 & 2008
