  • Congratulations waross on being selected by the Tek-Tips community for having the most helpful posts in the forums last week. Way to Go!
Trivial question on head loss conversion.
dbecker
138
0
0
I am trying to convert head loss of feet into corresponding pressure drop in psi.
If I multiply the height in feet by density which is in units of lbm/ft^3, then my result will not be pounds force per square foot, but pounds mass per square foot (this is not pressure!!!).
Am I missing something here?
Maybe this is obvious to everyone else, but it helps me to remember that the reason the 'customary pound' units are the way they are is this: normally (ie, here on the surface of the earth) a pound mass weighs a pound (force). The problem is, if you apply a force of 1 lbf to a mass of 1 lbm, it does not accelerate at 1 ft/sec2; in fact it accelerates at 32.2 ft/sec2.
That's really the source of all (my) confusion, and the reasons why the units are set up to confuse me. Like I said, understanding that helps me put the 32.2 in where it goes.
Actually that depends in which direction the force is applied and acceleration would be 33.2 ft/sec, if the force was applied downward not 32.2.
"Pumping accounts for 20% of the world’s energy used by electric motors and 25-50% of the total electrical energy usage in certain industrial facilities."-DOE statistic (Note: Make that 99% for pipeline companies)
