Trouble driving parent child constraints 1
bartbrejcha
New member
Jul 1, 2013
23
Im haviing a spot of bother driving parent child constraints with respect to splines.
What Im trying to accomplish is an Industrial designers trick of proving form. For example, Ill build a structure of parametric curves then tie 3 or 5 degree splines to those sketch structures as a separate sketch. I'm loosing my tangent/curvature upon manipulating the geometry.
Iv'e tried the studio curve w/ pols & w/o
Maybe Im doing something wrong or sketcher tangent is not to work like this.
Bart brejcha training consultant
Without an sample part there is really not much that anyone could say about what it is that you're attempting to do.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
< Im basically trying to recreate this model with the same worklow characteristics. I want to adjust what I call the underlying curve geometry and the studio curves/splines update. Currently it seams my tangent dis-associates when I make changes.
I've got a hand full of industrial designers that have asked me to help them learn UG as their company has made a decision to drop solidworks and move to UG/NX
Curve is tangeny all in once sketch
once moved the spline is no longer tangent.
Try creating the spline through poles rather than through points; you'll gain more control that way. You may have to create the spline outside of the sketch for full control (some curvature constraints are not supported inside sketches).
www.nxjournaling.com
It would be best if you just provided the actual model!
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
