Bower7:
With your lack of any fundamental understanding of your problem, why would we trust that your assertion of fixity at the base can be trusted? That would be a function of the relative stiffness of the various parts at that joint, and the exact means of their attachment. Why wouldn’t this be treated like a thin shell tube (a tube column) under a compressive loading? Although, you haven’t bothered to give any dimension, thicknesses, loads, engineering details, etc. Are we dealing with a 100 ton load and 2” thick shell or 100lbs. and .125” thick shell, there is a difference in how you would approach the problem. Is the loading concentric and uniform? Then the loading (bearing stress) would be Bf (lbs./inch) or Bsi (lbs,/sq.inch) = P/(circumference)(shell thickness) at the top. The axial force/stress in the shell would be slightly larger Bf or Bsi/ cosθ, where θ is the cone angle from the vertical. Then, depending upon the length of the tube, the diameter and thickness of the tube, you do have buckling issues which must be evaluated.
