Trying a complex/wrong gear combination hypoid wheel to spiral pinion
rakkiran
HK
Hello Community,
I am trying to make a gear combination as mentioned. I want to use a hypoid gear pinion(the reason to use hypoid gearset is to get an offset) as input and I do not want an offset at the output shaft. How can this be achieved.
Basically I am trying to make a differential gearbox but with a hypoid gear. I have attached an idea I want to achieve. Input hypoid gear with offset and output with a spiral bevel pinion with zero offset.
Is the idea feasible? Any other ways or ideas in which I can achieve an offset on the input pinion and no offset on the output kindly let me know.
I am looking forward to suggestions and design changes from the community. Thank you All!!!
Raj Kiran.
 https://files.engineering.com/getfile.aspx?folder=6473f5be-2410-4282-8972-cfefb6542cf5&file=Picture1.png
A hypoid with zero offset is a spiral bevel, isn't it?
Yes, I guess.
So can I take a configuration as given in my trailing question (as shown in image)? Input hypoid pinion and output spiral pinion
