Trying to access the clipboard when recording a journal
E_Beccles
Automotive
GB
I have a separate bit of software that generates an empty part file, and also copies the part name to the clipboard.
Because the empty part has 'TBC' as it's name in the part attributes table I wish to record a journal that updates this attribute to whatever is saved in the clipboard at the click of a button.
Whenever I try and record the journal it records the end result rather than the actions. I've tried replacing the string in the journal code to Clipboard.GetText() but NX says it doesn't have access to the clipboard. I don't know anything about VBA and I'm kinda just hacking at it. Does anyone here have some pointers?
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Module Module86
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        If My.Computer.Clipboard.ContainsText Then
            lw.WriteLine(My.Computer.Clipboard.GetText)
        Else
            lw.WriteLine("** clipboard does not contain text **")
        End If
        lw.Close()
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
The code above works for me (NX 9, Win 7). It displays the text on the clipboard (if any) in the NX information window. If you get an error when running the code, can you post the error text or a screenshot of the error?
www.nxjournaling.com
Thank you very much for your reply.
The code you posted works well but I am struggling to apply it to edit the name attribute.
Below is one potential solution.
Code:
Option Strict Off
Imports System
Imports NXOpen
Module Module8
    Sub Main()
            Return
        End If
        lw.Open()
        Const attributeName As String = "TEST"
        Dim attributeInfo As NXObject.AttributeInformation
        Dim testVal As String
        If workPart.HasUserAttribute(attributeName, NXObject.AttributeType.String, -1) Then
            EditPartStringAttribute(attributeName, My.Computer.Clipboard.GetText)
        Else
            lw.WriteLine("the work part does not have a number attribute named: " & attributeName)
        End If
        lw.Close()
    End Sub
    Sub EditPartStringAttribute(ByVal attName As String, ByVal attValue As String)
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "update name attribute")
        Dim objects1(0) As NXObject
        objects1(0) = workPart
        Dim attributePropertiesBuilder1 As AttributePropertiesBuilder
        attributePropertiesBuilder1 = theSession.AttributeManager.CreateAttributePropertiesBuilder(workPart, objects1, AttributePropertiesBuilder.OperationType.None)
        attributePropertiesBuilder1.DataType = AttributePropertiesBaseBuilder.DataTypeOptions.String
        attributePropertiesBuilder1.Title = attName
        attributePropertiesBuilder1.IsArray = False
        attributePropertiesBuilder1.StringValue = attValue
        Dim nXObject1 As NXObject
        nXObject1 = attributePropertiesBuilder1.Commit()
        Dim nErrs1 As Integer
        nErrs1 = theSession.UpdateManager.DoUpdate(markId1)
        attributePropertiesBuilder1.Destroy()
    End Sub
    End Function
End Module
