Trying to solve 4 equations in matlab!
lou1234
Materials
Apr 3, 2014
4
Hi I am trying to solve the following equations using Matlab for C1, C2, C3 and C4. In real fact I only require C1.
C1-C2-C3-1=0
n*C2+C3/n+(d-1)*C4=0
C1+b*C2-b*C3-1=0
b*n*C2-b*C3/n-C4(1+d)=0
This is what I have input in Matlab but it seems its getting stuck because of the symbolic expresssion??
Any help please?
syms C1 C2 C3 C4 g L g_0 dL
n=exp(-g*L)
d=exp(-2*g_0*dL)
solve(C1-C2-C3-1, n*C2+C3/n+(d-1)*C4, C1+b*C2-b*C3-1, b*n*C2-b*C3/n-C4(1+d), C1)
I can't help but notice you have 4 equations and 4 unknowns, and your homework is to solve it in a programming environment called matrix laboratory.
Cheers
Greg Locock
g, L, dL are also unknown by that expression
"Simplicity is the ultimate sophistication." L. da Vinci
- Gian
and g_0
- Gian
I would like to solve for c1 in terms of g_0, DL etc..
You still have more unknowns than equations..
- Gian
Having more unknowns can yield many solutions. Here is what maple gave me:
Code:
> B := solve({n*C2+C3/n+(d-1)*C4 = 0, b*n*C2-C3/n-(1+d)*C4 = 0, C1-C2-C3-1 = 0, C1+b*C2-b*C3-1 = 0});
print(`output redirected...`); # input placeholder
     |     2 b C3 + 1 + b       C3 (-1 + b)
    < C1 = --------------, C2 = -----------, C3 = C3,
     |         1 + b               1 + b
           1          1
      C4 = - n C3 b - - n C3, b = b,
           2          2
                  2  2        2        2       \
          -2 b + b  n  - 2 b n  - 2 + n        |
      d = ------------------------------, n = n >,
                2                              |
               n  (-1 + b) (1 + b)             /
      {C1 = 1, C2 = 0, C3 = 0, C4 = 0, b = b, d = d, n = n}
- Gian
I have 4 equations and I need to find c1, c2, c3 and c4, so 4 equations, 4 unknowns
So put numbers (real values) in for those other symbolic representations and you are done in about 10 seconds.
- Gian
Can't do that as I require a general expression. Is that possible in Matlab? Any idea why my code is not working?
I was trying to see if you understood your fundamental mistake. You are NOT differentiating between constants and variables in your work. That is why I say you have more variables. Matlab thinks there are more than there are.
All you need to do it tell it which ones are vars. ...
Code:
Q= solve('C1-C2-C3-1','n*C2+C3/n+(d-1)*C4','C1+b*C2-b*C3-1','b*n*C2-b*C3/n-C4(1+d)','C1','C2','C3','C4');
Q.C1
- Gian
