alexchisholm
Chemical
We were recently doing a routine inspection on a heat exchanger in which LP steam is passed through the tubes to provide the reboiler heat to stream of hydrocarbon liquids. We were surprised to find, however, that there was substatial damage to the inside of the tubes and are a little confused as to why this has occured.
the initial theory was that as the tube bundle was largely oversized, this led to a great deal of tube flooding, and when the hot steam contacted the colder water sitting in the tubes, some description of cavitation ensues, causing the damage. the tube bundle has therefore been redesigned, and will be monitored. Was just wondering whether anybody has enountered similar problems in an exchanger and whether there is any solution?
Thanks for your help
Alex
Alex
