stuckoutthere
New member
- Mar 15, 2010
- 11
Good Afternoon,
I am looking to work out the volume of gas lost in a fractured tube line.
If I have a tube that measures 12mm outer diameter with a 1.5mm wall thickness giving a 9mm internal diameter that has a gas going through it at 150psi which develops a 1mm hole how would I calculate the volume of gas lost in 1 hour?
Any help will be gratefully received.
