Langless28
- Dec 29, 2014
- 14
Good morning everyone! I am designing an automation project in which I load tubes onto a core for an injection molding machine. I have designed a hopper for the tubes (roughly 3/8" OD, 33" long hollow PVC). Unfortunately I had a feeling the design would result in this but the only way I would know for sure is if I actually built the darn thing! I attached a picture for reference. The tubes are getting held up at the throat, either by friction of the tubes against the left wall or slight twisting in the tubes causing them to fall down the center path crooked causing a jam. Once the tubes are in the center slot area, they transfer as intended on a sled. FYI center slot is 1/2" wide, with the tube OD being 3/8".
Can anyone recommend a fix for this "jamming". I was thinking along the lines of a massager, or vibration to assist but wanted to reach out to any experts on the hopper/feed design world which I clearly could use some help.
Order of desired fixes:
1. Rigid, a plate or diverted can fix it.
2. Pneumatic element massager/prodder fingers.
3. Some other form of movement- gear motor etc.
*EDIT* picture needs to be rotated so the black plate is horizontal and on the bottom of the image.
