BS2
- Feb 10, 2012
- 65
I have a moment connection that I need to make work that consists of two tubes (snugly fit) nestled one inside the other. I have looked all over for information about what design checks may be applicable, but to no avail. The closest I could find was nested tapered utility pole calculations that used a linearly increasing distribution of the contact stresses. Does anyone have insight into how this issue might be calculated?
For specifics, the connection has a 2.875" diameter x 13 ga tube surrounding a 2.625" diameter x 11 ga tube with a 12" overlap. Additionally, the connection has two 3/8" through bolts.
Thanks for any insight that you may provide!
