enginerd74
I had posted this question in another forum, but maybe this is the best location for the question (with some added history).
__________
I am digging up some information on a proposed repair to fix leaks on one of our waste heat boilers, and am wondering what procedure and filler metal should be used to repair leaking orbital welds (very small pinholes) between the SA240 TP405 tubesheet (3/4") and the SA268 TP439 tubes (1-1/4" x 12 BWG).
I understand the past repairs on this boiler tubesheet/tube interface has been completed with 308, 309 &/or 310 (with limited sucess). The original drawing shows that Inconel 82 or 182 was to be used for the orbital welds.
Any specific help on this issue or direction to reading material that addresses these types of questions (I have similar questions for a proposed weld between 304H & Avesta 253MA) would be much appreciated.
As well, is there a book/website that does a good job as a primer to understanding this field?
__________
