tubing design
sudhakarn
Automotive
Apr 1, 2013
506
I am unable to define a run for a product opened from the enovia.This is actually a vehicle.the run toolbar is highlighted only when i activate the insatance of the product and even then i am getting the error as "unable to create run for the CAT Part.Activate the CAT Product ". Any body has any idea?
When i am working in a local product file it is fine there is no issue.
my guess is that tubing only works in CATProduct file, not enovia structure, at least with Enovia VPM V4.
V6 is something else.
Eric N.
thank you sir.I am also of the same opinion.
Make sure you are using a "Publications Exposed" product in ENOVIA. This will mean your product will show in the ENOVIA tree as a single "blackbox" node. When you open this in CATIA you will see the entire structure show up. I am not totally familiar with Tubing and it'll depend on which version of VPM you got. But I am coming at this suggestion from an Electrical Harnessing and VPM 1.6/3dcom background.
hi,
Thank you so much kevin.Will check it and get back to you.
