My friend has an issue regarding oil pressure/flow drop over a short distance I'd like to get other opinions on.
A GARRETT GT25 frame turbocharger requires only 35-40 psi of oil pressure supplied to bearing section to perform reliably (as per GARRETT). Anything above ~40 psi begins to force it's way past the seal and into the exhaust stream, thereby causing a smokey mess.
The oil pump he is using surpasses the 40 psi max by a lot, so a restrictor is necessary to decrease pressure/flow. Specifically, there is a oil supply routing that goes as follows:
Oil Pump-----Engine Block Junction------2ndary Junction---Turbocharger
GARRETT's technical department didn't have a solid explaination on the placement on the restrictor in the oil supply route. They only stated that the restrictor should be placed at the inlet of the turbocharger. I don't think he was an engineer, just customer service.
Can the restrictor be placed at the 2ndary junction, which is about 5" before the turbocharger inlet, without a critical pressure/flow drop (beyond what's necessary for turbocharger oil supply)?
