psychedomination
- Jan 21, 2016
- 123
I am currently working on a bridge that has slip critical connections. The bolts need to be pre-tensioned to about 170kN. The method chosen to pretension the bolts was the turn of the nut method, using a 1/3 turn. I am having some issues with the contractor in achieving this third of a turn. It was originally thought that the contractor would snug tight the bolts and then extend the lever arm of a wrench with a piece of steel pipe or something to turn the nut a 1/3 of the way. The contractor is stating that there will not be enough space under the bridge to use an ~ 4' lever arm. Fair enough... due to the lack of space I told the contractor to use an impact gun to snug tight the bolt and also use an impact gun to turn the bolt a third of a turn. They originally used a 3/4 impact gun, however, it only turned the nut about 1/4 turn.
They used this gun :
I told them to use a more powerful 1" air impact gun. I was under the impression that impact guns can actually break bolts. So will a more powerful 1" air impact gun get at least a 1/3 turn?
BTW they are using 20mm diameter A325 bolts that are 80mm long if that makes any difference.
Any help or advice with methodology would be greatly appreciated.
