I have a problem and am not sure what to do. I have a part and it is to be made from stainless steel round bar stock. The wall thickness that is called out is .030" and the length is 1.00". The id tolerance is +/- .001. Any ideas on how this can be machined without crushing the part? The part is not a tube, one end is a thin walled tube the other is a solid end with a small drill hole. I was thinking maybe finishing the id and centerless grinding the od down to size, but I think this will crush the part also. Any ideas will be greatly appreciated.
jdm
"Education is what remains after one has forgotten everything he learned in school." Albert Einstein
jdm
