Theophilus
- Dec 4, 2002
- 3,407
I've got a compression spring that gives me the function I need, but is a bit too large a diameter. Is there a way for me to figure out how to turn this single spring (21 winds over 6", .188" diameter wire, 1.0" OD) into two springs that would deliver similar force as what I've got, each with less OD? The spring is compressed just under an inch in a normal working cycle.
I'd appreciate any direction as to how to figure this out. Thanks!
Jeff Mowry
Reason trumps all. And awe transcends reason.
Jeff Mowry
