Eclair
- Oct 14, 2007
- 12
Hi everyone like me,
A setup of two exactly similar transformer of about 22MVA connected togother via a tie breaker has a downstream earth fault.
I figure out that the ground resistors (400A) of each transfomer will contribute of a ground/earth fault for 800A.
How can I solve the problem: where is the fault? And how can I shutdown one the good problematic transformer?
I guess it is with a differential relay that this problem could be solve. But how and where in my circuit?
Thank you
Thank you
