Thanks,
(for some reason I can't seem to find the specific reply to each response, so I'll reply in one post)
The process is separation of n-Butane (gas) from water (liquid).
about 10 bara and 80 °C (though the pressure and temperature can vary).
flow ratio is about 8%vol gas in mostly liquid flow.
The assumed bubble size is about 0.1 mm.
I am looking for ways to improve separation and avoid bubble running with the liquid.
I did a preliminary sizing of a horizontal separator, but need to reduce the retention time, as i am limited with size.
In order to compensate for the short retention time, I assume that some sort of a coalescer is needed, maybe in addition to flow manipulation (buffles).
I would appreciate any input on the options and how each contributes to the separation.
Thanks,
