Does anyone know how to calculate the following. I am going to be assembling two shafts together using a shrink fit, coating the interior of the two shafts with loctite, then welding the mating point of the two shafts with a fillet weld. The outer shaft will be attached at the bottom to a gear box, then the inner shaft will attach at the top to a coupling, as the top of the inner shaft has a coupling as well. I need to figure out how to determine whether the inner shaft will slip when the gear box shaft starts turning the outer shaft. I know I have not given any values, but I was wondering if anyone has ever had to perform an analysis similar to this. Any help is welcome.
Cheers,
Tom
Cheers,
Tom
