Type mismatch when creating function (API)
razzendahcuben
I am confused as to why I am getting a type mismatch here. Any insight would be greatly appreciated.
Dim swApp As SldWorks.SldWorks
Dim swModel As SldWorks.ModelDoc2
Sub main()
Set swApp = Application.SldWorks
Set swModel = swApp.ActiveDoc
MsgBox IsPartOpen(swApp)
End Sub
Function IsPartOpen(app As Application.SldWorks) As Boolean
If swModel.GetType = swPartDOC Then
IsPartOpen = True
Else
IsPartOpen = False
End If
End Function
Which line?
What are you trying to do?
Is there actually a part open?
-handleman, CSWP (The new, easy test)
Thanks for the response. To answer your question:
The first line of the function is the problem (Function IsPartOpen).
Yes, there is a part open.
The function tests whether a part is open.
You are using an object swPartDoc when you need an integer.
I believe that you need to move the:
line down into the function. In general, a variable of a given name inside one function is not linked to variables of the same name in different functions / subs.
Eric
Thanks for your input, guys. I tried both suggestions but same error still. I'll keep playing around with it...
"swPartDoc" is an object class. It is a reserved word. You need to define a variable that is a number (long type) for GetType.
swDocPART, not swPartDoc.
Found the problem. "app as Application.SldWorks" needs to be "app as SldWorks.SldWorks.", then the type mismatch error goes away.
I'll correct the other error you pointed out as well. Thanks.
