UAT-1 1
MoonshadowXIII
thread240-24000
"DRWeig (Electrical)
28 May 02 10:30
Hi BFuddled,
Kele has a device (UCS-121 or UCS-221) that does this trick, and if you need to scale the input, there is a UAT-1 that can do that too.
Have a look, the web is and it's in the product catalog under output transducers.
Let me know if you need more info.
Old Dave"
Dave,
I know this was thread was a while back, but I have a question for you. BFuddled wanted to turn ON at a set voltage then OFF again at another voltage. I too want the same thing. I want to come ON at between 3.5vdc and 5vdc, anything above or below I want to be OFF. Question: Will the UAT-1 you mentioned accomplish this? I have read the docs from KELE, but I'm afraid I just don't understand the lingo enough to know if it will. If it isn't too much trouble for you, could you please let me know if it will do what I described?
Thanks!
Moon
Well guys I promised to give an update when I got it all put together..... So
The UCS-221 controller finally showed up. It was pretty simple to calibrate. Since I already had the Solid State Relay and had it wired and mounted in my control box, I just used the controller board with the 24vdc power supply to trigger the relay instead of wiring the regulator direct to the board. I simply plugged the control board power supply into a timer to ensure it doesn't activate the CO2 at night. I've had it in operation for the last 24 hours and thus far it seems to functioning perfectly! :) It maintained 1100-1300 ppm all day yesterday. I went out around 9pm last night to checked in to find the levels had dropped to about 600 ppm, just as expected. I went out and checked this morning and the system powered up as intended and the ppm levels are about 1200. I couldn't be more pleased.
Dave, Thank you VERY much for all your help on this project. And I want to thank everyone for all the useful input. I'm very grateful.
Since my last post I have been doing considerable research into the computer controlled concept.... I'm very intrigued by this, and want to begin designing the system. So, I will likely be back with more dumb questions ;)
Cheers!
Moon
Congrats, MoonshadowXIII!
Good on ya,
Goober Dave
Haven't see the forum policies? Do so now: Forum Policies
