UDE managing in a program (VB)
Thierry SEGUI
New member
May 28, 2021
12
Hi all,
In the manufacturing environnement of NX, I would like to add, destroy and modify start UDEs of a program.
In the example below, I'd like to change "DISPLY/PART NAME = FLANGE" into "DISPLY/PART NAME = FITTING"
=> If I find a start UDE that contains "DISPLY/PART NAME = " then I modify it.
=> If I don't find that UDE, then I create it, and edit the command line "DISPLY/PART NAME = FITTING".
Is it even possible in a VB journal ?
Thierry
So far, I can get the program (CAMObject) from the list of programs (NCGroup). But now I'm stuck : I found some intresting things in the NXOpen class librairy, but I don't know at all how to implement them :
NXOpen.CAM.Ude / UdeList / UdeSet (…) classes look promising, don't they ?
The base for NXOpen.CAM.Ude is an NXOpen.TaggedObject.
You can use : NXOpen.Utilities.NXObjectManager.Get(yourcamobjTag) to get this.
