UFUNC help
engguser
14
I created one UI styler menu. I added a integer to that menu. This integer field should accept any value except 25.
Any idea how I should do it.
regards
engguser
Dave,
Thanks for the info. I tried the option you have mentioned.
The integer field has a ACTIVATE callback. I thought of doing the check here so that when the field loses the focus it will verify. But this callback is never called or activated.
Any idea how I should do that.
regards
engguser
