We welded PQR test coupon using 35 mm thick plate, impact testing is a requirement per Section VIII-1 and qualification standard is Section IX. Now, the qualified range of base metal is 16 to 70 mm.
Now per UG-84(h)(2)(c) required minimum impact energy values shall be taken against 70 mm instead of 35 mm from Fig-UG-84.1, is it correct?
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
Nasir
Welding Engineer
PAKISTAN
