mhrub
- Jun 20, 2012
- 16
I was just wondering if anyone has had this problem happen to them. When I try to delete components out of assemblies, either by right clicking the name in the file tree or clicking on the component itself it does not delete. It does not ask me anything like "Are you sure you want to delete this component", nothing. I had this problem before we upgraded from NX 7.5.0.32 and it still is happening in this version. Here is a post from my log file when I go to delete a component:
!GIT: prog, mb0/0+0, U_desel_all (P:2)
&MACRO SUB_SELECT 3
&MACRO CUSTOM 25 ANT * TL_SELECT * RP1501-2070_airfoil-mill-fixture_rev-.prt% 3 * 0 * 1 ! DIAMOND-PIN_.25X.1875X.75_X_T
&MACRO MENU, 0, UG_EDIT_DELETE UG_GATEWAY_MAIN_MENUBAR ! < Delete>
&MACRO MENU, 0, UG_HELP_SYSTEM_LOG UG_GATEWAY_MAIN_MENUBAR ! <MB/Toolbar>
I have tried making new files, older files, none of them can delete things out of assemblies. Is this an option I have turned off???
Thanks in advanced,
Mike
&MACRO SUB_SELECT 3
Thanks in advanced,
Mike
