Ug Nx on XPpro Sp1 Problem??
Chris1212
New member
Nov 24, 2002
1
Hi
I'm running Ug NX on Windows XPpro,..Service Pack 1
There is lot of problem with that.
1- Ug can't remember menu positions nor menu settings
2- Ug can't locate recent open files,..seem to be a
coruption of windows registry
I tried UG version 18,..it do all the same,..
it seem to be a problem from xp sp1
If u have heard about a solution ,..please let me know about.
The problem is UG is trying to run in Win2000 mode.
Rename this file "ungraphics.sdb" in the UGII folder to "ungraphics.bak" and start UG, it should work.
Mick
Did this correct your problem? I tried renaming the unigraphics.sdb file, and it didnt change anything. Are there any other suggestions?
Check out the official UG BBS in the CAD conference. The fix is in there, just posted this afternoon.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
Appologies.
Uninstall unigraphics.sdb first then rename.
Use
sdb inst -u unigraphics.sdb
