UGOPEN API: Popup Supression
bistromathics
Computer
Oct 28, 2011
13
I am using the UGOPEN API in NX 7.5 to try and automate the inspection of a batch of Unigraphics files. However, there is a file causing the following popup-dialog:
"Features added in the Modeling environment may not be properly depicted in a flat pattern. Some Modeling operations may make the sheet metal part unusable."
This dialog box blocks further processing of NX data until I manually click "ok". I am wondering if there is any way to tell NX to hide pop-ups like this? Or any way to programmatically close the popup?
Thanks!
