Hi All, Is there a way I can have a personal UI settings when it restored from server after every restart, I am mainly annoid with the options menu popping out with every command, each time I need to check do not show again.
then toolbars, performace settings, assembly fast options, command tips etc..
I cannot tell them to change because they need it since all of them are getting trained.
