zenzizenzizenzic
Student
- Dec 3, 2023
- 3
Update:
Previous Message:
Hi. Please help or at least give hints on how to resolve the following warnings and errors. I am using GUI. Thank you in advance! I have attached the input file in .txt format.
Warning Messages:
The general contact domain for modeling contact interactions in Abaqus/Standard has double-sided facets. Initial contact adjustments for resolving gaps and overclosures when a surface with double-sided facets is paired with any surface having double-sided facets may be incorrect. Similarly, adjustments for double-sided surfaces crossing each other may be incorrect and no additional warnings or error messages will be issued. In all these cases, we recommend using single-sided surfaces under *CONTACT INITIALIZATION ASSIGNMENT to handle initial adjustments more precisely and avoid possible convergence problems.
112 nodes have been adjusted. The nodes have been identified in node set WarnNodeAdjust.
Error Messages:
THERE ARE NO RIGID REFERENCE NODE ASSOCIATED WITH SURFACE General_Contact_Faces_4
THERE ARE NO RIGID REFERENCE NODE ASSOCIATED WITH SURFACE General_Contact_Faces_5
THERE ARE NO RIGID REFERENCE NODE ASSOCIATED WITH SURFACE General_Contact_Faces_6
THERE ARE NO RIGID REFERENCE NODE ASSOCIATED WITH SURFACE General_Contact_Faces_7
Analysis Input File Processor exited with an error.
New Issues:
Node set assembly_bolt-1_bolt-refpt_ has no members and will be ignored. Nodes defined in this set may have been deleted because they were not connected to any elements.
I will post the new input files if anyone is interested.
Previous Message:
Warning Messages:
Error Messages:
New Issues:
