Ultrasonic flow meters - high temprature countries for house connections - Water 2
Baram
Agricultural
Mar 3, 2012
33
Hello All,
I would like to ask about disadvantages of using ultrasonic flow meters for househeld connections in hot climate.
application: domestic water
Water pressure: 30 psi
water source: desalinated water
meter location: outside of buildings and fixed in plastic box in the wall.
The problem that my country temperature in summer monthes is 40-50 C degree, the plastic box will keep higher temrature around the meter higher than atmospheric temprature.
I heared that hot weather affects meter battery and LCD screen, also I heared that to use these type of meters water should be clear and does not contain any solids.
I know that ultrasonic meters accuracy is better than mechanical meters or mag meters
I would like to know from our experts if ultrasonic meters will be good idea in such application?
Please find the attached for 2 different meter models.
Thanks in advance,
Baram
Seems to me you should talk directly with the manufacturer. The datasheets imply operation up to 60°C, but does not explicitly state it.
TTFN
faq731-376
7ofakss
You're comparing Apples with Oranges for technologies
The SM250 spec sheet says, "Uses fluidic oscillation technology" (top, page 2). That's not ultrasonic.
I'm a doubting Thomas. I do not believe the EMS with active sensor can get a 20 year life span out of a non-replaceable lithium battery.
Sorry, I only as about the ultrasonic flow meters which is Badger meter
I have zero experience with that ultrasonic meter but I've not had good experiences with other manufacturers on accuracy. Others haven't either. On a home line, it may suit your purposes. I don't see a problem with your ambient temperature. You'll need to make sure you have enough piping to properly install whatever you pick.
Pamela K. Quillin, P.E.
Quillin Engineering, LLC
