Another late comer to the thread.
I am a UT Level III. Our shop has made many Inconel Clad vessels. I wouldn't be too hard on your first inspector. While I agree with the formulas and numbers the NDEGUY quotes, those formulas tend to break down because they do nto consider the anisotropic nature of Inconel. If you run the numbers, you should get the same reflection (discounting beam attenuation) whether you test from the Inconel or from the Carbon side. In real world - it isn't even close. If you try to get an interface signal from the Inconel side, you won't get anything back. If you try from the carbon side you will get a big signal.
If you are still listening James01, when the original inspection was performed, was the unit filled with water? If it was, the inspector was set-up. The majority of the little bit of sound that made it into the Inconel probably coupled straight into the water (again not so per the formulas - but definitely so in the real world) and he didn't get a strong enough signal to read, or the signal was weak and could not be resolved from the clad interface signal.
Of course, maybe he didn't know what he was doing.
