ULTRASONIC TEST REQUIREMENT AS PER ASME SECTION V & VIII
Sumit bhadakwad
16
Hello everyone experts , I want help from all of you .
We are going to manufacture a base frame in which no.of different size thickness plates are used
But our client said above 25 mm thickness , UT is mandatory .
IS it mandatory ? If yes where it is given in ASME.
Sorry but you are wasting peoples time with your question.
1 If the client wants it then it is mandatory (if it is in your contract documents) irrespective of what the code states.
2 If it is not in your contract documents then ask the client where it is noted in ASME.
You are fabricating a base frame in accordance with ASME VIII ?
Hello everyone ,
If have any answer plz tell me . Ut as per ASME .
