Amitesh8532
Materials
Dear All!
Greeting from my side!!
I have gone through the Ultrasonic testing of the Alloy steel with Plate thickness > 6 mm. Now I am exploring to do the UT in final products [as thin sheets of Alloy Steel] in thickness 2-4 mm. First I have done with UT in 2-4 mm thickness with conventional methods but the echoes that we receive is not coherent. So, my First Question is is there is any process/ASTM standards to carry out the UT test in 2-4 mm thickness? What is the type of machines required do the UT testing in 2-4 mm thickness? And if not, what is the possible ways to do the UT?
All suggestions and solution are welcome. Thanks you all !!
