  • Congratulations Toost on being selected by the Eng-Tips community for having the most helpful posts in the forums last week. Way to Go!
Unable to select a sketched entity in a drawing
Figbash
46
I would like to add a sketched circle to a drawing to dimension a V-groove. I can sketch the circle ok and convert it to a construction line, but am unable to select the circle itself or its center to create a dimension to the part. I have done this in the past with no problem, but this time it's giving me fits. Is there some way to make the sketched circle selectable?
Have you checked your selection filters? Go to view -> toolbars -> and click selection filters. Make sure that at minimum the filter for sketches is on.
Got it!
"Lock View Focus" had to be selected in the view before making the sketch. Then the sketched enity could be tird to the drawing view.
