Hello together,
I am working in Windows7 with NX11 in the mechanical routing environment. I wanted to add some parts to the routing reuse library and created the .ptb file. Also updated the .plv accordingly. After I refreshed the library, NX switched to the view tab and the routing environment is not longer available. Attached picture shows how it looks. Same after restarting NX. The modelling environment is working as it should.
Does anyone know how to fix this issue?
