NucEngineer
Nuclear
- Jul 26, 2015
- 5
Hello all,
I am looking at replacing a failed compressor pump with a larger displacement pump, and I will be under driving the replacement pump for several reasons. I am wondering if I will have oiling issues as a result.
Manufacturer specified speed range for the new pump is 655 - 1050 rpm. I want to run the pump at 595 rpm.
So the obvious question here, do you guys think that I will have oiling problems running 60 RPMs less than minimum spec? This will be home use application, so not 7 days/wk production use.
Thanks.
Thanks.
