underground pipelne 3
engfir
Petroleum
EG
i have sveral pipelines that must pass underground of the highway
the pipelines are for different product with different diameters
1_ steam pipeline
2- saturated water
3- jet
4- fire fighting pipeline
5- oil pipeline
i don't know how to calculate safe distance between these pipelines so please if you could help me or tell me the standard
For parallel large diameter pipelines, concern should be given to pipe-trench interaction and trench requirements.
When buried pipes are installed in parallel, principles of analysis for single pipes still apply, however soil cover must be greater than minimum. In other word, the design of parallel buried pipes requires an additional analysis for heavy surface loads (given that a common trench is used). In fact for buried parallel pipes soil slip between the pipes becomes the bottleneck for the distance calculation. Talking about 1 m or more separation then the concern becomes faded but it all depends on your pipelines diameters and soil density.
If the pipelines are in separate trenches, then embedment stability becomes a concern when a trench is excavated parallel to an existing buried flexible pipe. You should address what would happen to a buried flexible pipe when some or all the side support is removed in a parallel excavation. Ans also the existing trench stability itself is an issue to concern. At less than minimum side cover, X, side support is lost and the soil on the pipe must be supported by the pipe. If ring stiffness is inadequate, the pipe collapses.
For a detailed discussion, please refer to "Buried Pipe Design" by A. P. Moser, Steven Folkman chapter 3.
Maybe we should give an award for OP most involved in his own thread- engfir seems to fit the bill.
repeat. "Surely you're joking. "
More like expert in getting others to become involved.
We've circled back to buried pipes, except they are now in culverts.
From "BigInch's Extremely simple theory of everything."
