Underground Storage Tank, Fill Pipe Covers
4winds
5
I am looking for information on the height
specifications of underground [ petroleum ]
storage tanks, fill pipe covers.
These covers are the ones you typically see
over the underground tanks, at typical
fueling stations. Some are installed
flush at grade, and others are installed
with the covers slightly above surrounding
grade.
Is there a height limitation [ maximum ]
above the surrounding grade ? In the
Underground Storage Tank ( UST ) research
that I have looked at online, ...the
language only says that none of the covers
shall be installed below grade ( recessed ).
Thanks for any help
Will these covers have any traffic loads on them? Maybe AASHTO H20 loading, or more? If so, then they should probably have a minimal projection above grade, so as to not impede tanker truck traffic. If these are manways only, and have no traffic loads, then they should project far enough above grade, maybe 3" - 6", or so, so they don't collect water. If they are in a grassy area which has to be mowed by tractor, then you might want to consider that as a potential minimum vehicle load too.
Dave
Thaidavid
thaidavid40,
Thanks for the reply !
The Fill Pipe Covers will have vehicular traffic
on them......Typical low weight vehicles, and
the petroleum supply tankers as well.
I did not see anything in the AASHTO H20 Specs.
that mentioned "designed heights" on these type
of covers.
Possibly, ...do you know of any other resources
besides AASHTO ?
