A stone dam approx. 30 ft long and 4 feet tall has water seeping below the stone at each end. Scouring indicates stormwater flows over the top at both ends causing loss of soil at the downstream base of the dam causing weak points for water to undermine the dam. Assuming the side erosion caused by overtopping problem is fixed, what is an effective way to stop the undermining?
