Transient1
- Jan 31, 2007
- 267
Hi all,
I haven't looked at psychrometric equations since undergrad. I'm trying to lock down a method for determing if condesation could occur under a given set of conditions. The problem set up is that we have an oven for thermal cycling (-5 C to 76 C). There is a hole(*~4inches Diameter) in the oven that our test guys run a small (1/4 inch hose) through and then pump nitrogen in at 2 SCFH. The chamber is 4 Cubic Feet in Volume and the relative humidity is mainted at 55%. There is an unknown leak rate out of the oven. If I assume that it is less than 1 SCFH, then I could safely say that during the test the mixture in the oven is 1 CF nitrogen and 3 CF air/vapor mixture.
So I think I solve this problem as follows:
Since I know the relative humidity I can calculate the partial pressure of each gas. Then I can follow an example problem of calculating the specific humidity. Where I use the specific humidity and the initial temeprature (room temeprature) to determine what the dew point is. As I write this I have a thought that as long as any water vapor is present it will condensate in the given temperature range.
Thanks for your help.
