LoadMonitor
Hi can anyone tell me if I had the following readings how could I calculate kw. The readings were taken from an electricity meter which logged the values every 15 minutes and the values below are what were recorded in the first 15 minute period;
A+ Energy Total = 3920Wh
A- Energy Total = 3480Wh
Q+ Energy Total = 3960varh
Q- Energy Total = 2920varh
S+ Energy Total = 3920Wh
S- Energy Total = 7440Wh
Really what I need to figure out is how do you get the absolute values based on the positive and negative values.
I think as the values have h after them they are hour values, but as the values are recorded every 15 minutes I am not sure what to do with them.
Also I believe the values A,Q and S make up the power triangle but I cant get the equation to balance if you square them.
I have tried adding them and squaring them but I still cant get it to balance.
Any help appreciated.
